Hello,
I need to run several Sun Blade 2500 workstations each equipped with dual XVR-600 graphics cards. The machines are running Solaris 8. Changing the OS (e.g. to Solaris 9/10) is not an option.
They need to run at a resolution 1600x1200x75.
This works fine with a native 3rd party 1600x1200 monitor.
Since buying TFT monitors with that native resolution is kind of difficult nowadays, I thought:
"Why not try and connect a 1920x1200 monitor to that workstation and live with black stripes to the left and right?
Unfortunately my tries with a Lenovo Thinkvision LT2452pwc did show no success.
The monitor displays "signal out of range", which I take as an indication that there IS a signal, but it simply does not match the accepted range of that monitor.
The monitors specification does list 1600x1200 with 75 Hz, though.
So my question is:
What would be the trick to make the above mentioned combination work?
Does anybody have positive experience with connecting an up-to-date 1920x1200 monitor to a machine like the ones I use? I would love to receive your recommendations for a specific model?
A fallback option might also be to change the refresh rate to 60Hz, but my tries with "fbconfig -dev jfb0 -res 1600x1200x60" did not change anything, the adapter still works at 75Hz...
thanks in advance!
