Skip to Main Content
E-Business Suite
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
String Index out of bounds : 3 issue when running a simple page from Jdeveloper
Anson Jones Paul Arul SinghMar 18 2024 — edited Mar 18 2024
Tried to setup a new version of Jdeveloper for our upgraded EBS version, but getting the below error in the the logs.
java.lang.StringIndexOutOfBoundsException: String index out of range: 3
at java.lang.String.substring(String.java:1934)
at oracle.jdeveloper.compiler.OjcConfiguration.getSource(OjcConfiguration.java:281)
at oracle.jdevimpl.runner.oc4j.Oc4jWorkspaceConfig.ensureJavaCompilerIsSet(Oc4jWorkspaceConfig.java:1082)
at oracle.jdevimpl.runner.oc4j.Oc4jWorkspaceConfig.configureAll(Oc4jWorkspaceConfig.java:169)
at oracle.jdevimpl.runner.oc4j.Oc4jStarter.preStart(Oc4jStarter.java:631)
at oracle.jdevimpl.runner.oc4j.Oc4jStarter.start(Oc4jStarter.java:269)
at oracle.ide.runner.RunProcess.startTarget(RunProcess.java:830)
at oracle.jdeveloper.runner.JRunProcess.startTarget(JRunProcess.java:473)
at oracle.jdevimpl.runner.run.RunningProcess.startTarget(RunningProcess.java:76)
at oracle.ide.runner.RunProcess$2$1.run(RunProcess.java:768)
at java.awt.event.InvocationEvent.dispatch(InvocationEvent.java:209)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:597)
at java.awt.EventDispatchThread.pumpOneEventForFilters(EventDispatchThread.java:269)
at java.awt.EventDispatchThread.pumpEventsForFilter(EventDispatchThread.java:184)
at java.awt.EventDispatchThread.pumpEventsForHierarchy(EventDispatchThread.java:174)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:169)
at java.awt.EventDispatchThread.pumpEvents(EventDispatchThread.java:161)
at java.awt.EventDispatchThread.run(EventDispatchThread.java:122)
#### Embedded OC4J Server could not be started up.
I'm getting this error as well shown below.
When I try to open the Embedded OC4J preferences, I'm getting an error there again.
at oracle.jdevimpl.runner.oc4j.EmbeddedServerAdminCommand.doit(EmbeddedServerAdminCommand.java:50)
at oracle.ide.controller.CommandProcessor.invoke(CommandProcessor.java:259)
at oracle.ide.controller.IdeAction.performAction(IdeAction.java:541)
at oracle.ide.controller.IdeAction$1.run(IdeAction.java:772)
at oracle.ide.controller.IdeAction.actionPerformedImpl(IdeAction.java:789)
at oracle.ide.controller.IdeAction.actionPerformed(IdeAction.java:498)
at javax.swing.AbstractButton.fireActionPerformed(AbstractButton.java:1995)
at javax.swing.AbstractButton$Handler.actionPerformed(AbstractButton.java:2318)
at javax.swing.DefaultButtonModel.fireActionPerformed(DefaultButtonModel.java:387)
at javax.swing.DefaultButtonModel.setPressed(DefaultButtonModel.java:242)
at javax.swing.AbstractButton.doClick(AbstractButton.java:357)
at javax.swing.plaf.basic.BasicMenuItemUI.doClick(BasicMenuItemUI.java:809)
at javax.swing.plaf.basic.BasicMenuItemUI$Handler.mouseReleased(BasicMenuItemUI.java:850)
at java.awt.Component.processMouseEvent(Component.java:6267)
at javax.swing.JComponent.processMouseEvent(JComponent.java:3267)
at java.awt.Component.processEvent(Component.java:6032)
at java.awt.Container.processEvent(Container.java:2041)
at java.awt.Component.dispatchEventImpl(Component.java:4630)
at java.awt.Container.dispatchEventImpl(Container.java:2099)
at java.awt.Component.dispatchEvent(Component.java:4460)
at java.awt.LightweightDispatcher.retargetMouseEvent(Container.java:4577)
at java.awt.LightweightDispatcher.processMouseEvent(Container.java:4238)
at java.awt.LightweightDispatcher.dispatchEvent(Container.java:4168)
at java.awt.Container.dispatchEventImpl(Container.java:2085)
at java.awt.Window.dispatchEventImpl(Window.java:2478)
at java.awt.EventQueue.dispatchEvent(EventQueue.java:599)
Can someone please help, as we are stuck with this for more than a few weeks.
Jdeveloper version detials below
Thanks & Regards,
Anson Jones
Comments
Post Details
Added on Mar 18 2024
1 comment
