Hi Friends,
Need you urgent help in using listagg function for more than 8000 char.
I did the below sample SQL and in "e_orig" and "d_orig" for upto 4000 char it is working fine but I have to use it for more than 8000 char. and it is giving error,
I checked the listagg function is having limitation of 4000 char.
I tried but I am unable to achive this. Can someone provide me a sample example to achive this
select d.dname,d.loc,e.hiredate
,listagg(e.ename,',' ) within group (order by e.deptno) over (partition by e.deptno) as e_orig
,listagg(e.ename, ',') within group (order by e.sal) over (partition by e.deptno) as d_orig
from emp e, dept d
where e.deptno=d.deptno;
[ This is my first post, I gone through the guideline for posting a post , and try to go according to that ( I have not pasted here create table and insert as I have used basic table emp, dept for example), please let me know if still I should give this, I will take care from my next post ]
Thanks in advance
