Hi all, I'm not sure how many people will see this page but just wanted to share my SQL project related to discounted cash flow (DCF) valuation method. DCF valuation is a method used by finance guys (not myself, I'm an accounting auditor) to derive projected values of investments like stocks. I have no professional experience in SQL, and this is my very first project, so please be kind.. or not.. :)
I'm sharing this project so that those who need it can use it (obviously), but also because whole project is a HUGE MESS (lots of nested selects, too long in general, way too specific financial statement line item names, etc.), and I'm hoping to gain more insights from professionals to optimize the lines. The stock used in my project is Microsoft (ticker: msft). You can download the data using python's yfinance (Yahoo Finance) and clean them up using MS Excel. I've included a short guide for data cleaning (is this even the right term..??).
'<File Import>
#step 1: import s&p historical prices, stock historical prices, stock financial statements as csv from yfinance
#step 2: rename columns of s&p historical prices and stock historical prices csv files to "date" for the first column and lower-cased and underscored names for the other columns
#step 3: rename stock financial statements (all 3) columns from date format to text format (e.g. q2_24), then transpose the tables'
_____________________________________________________________________________________________________________________________________________________________________________
'<Finding Beta>
#step 1: load s&p historical prices and stock historical prices to the database and join the two tables
#step 2: calculate beta using slope method as a separate table
Assumption: stock daily gain over 15% is exempted'
CREATE TABLE stock_sp_table AS
WITH stock_table AS (
SELECT date(date) AS stock_date, close AS stock_close,
(close + close - sum(close) OVER(ORDER BY date ROWS BETWEEN 1 PRECEDING AND CURRENT ROW))/(sum(close) OVER(ORDER BY date ROWS BETWEEN 1 PRECEDING AND CURRENT ROW) - close) AS stock_daily_gain,
((close - LEAD(close, 30) OVER (ORDER BY date)) / LEAD(close, 30) OVER (ORDER BY date) * 100) AS stock_futr_30,
avg(close) OVER(ORDER BY date ROWS BETWEEN 4 PRECEDING AND CURRENT ROW) AS stock_mav_5,
avg(close) OVER(ORDER BY date ROWS BETWEEN 29 PRECEDING AND CURRENT ROW) AS stock_mav_30,
close - (SELECT avg(close) FROM stock_db) AS stock_dev
FROM stock_db
WHERE date > 2000
sp_table AS (
SELECT date(date) AS sp_date, close AS sp_close,
(close + close - sum(close) OVER(ORDER BY date ROWS BETWEEN 1 PRECEDING AND CURRENT ROW))/(sum(close) OVER(ORDER BY date ROWS BETWEEN 1 PRECEDING AND CURRENT ROW) - close) AS sp_daily_gain,
((close - LAG(close, 30) OVER (ORDER BY date)) / LAG(close, 30) OVER (ORDER BY date) * 100) AS sp_past_30,
avg(close) OVER(ORDER BY date ROWS BETWEEN 4 PRECEDING AND CURRENT ROW) AS sp_mav_5,
avg(close) OVER(ORDER BY date ROWS BETWEEN 29 PRECEDING AND CURRENT ROW) AS sp_mav_30,
close - (SELECT avg(close) FROM sp_db) AS sp_dev,
(close - (SELECT avg(close) FROM sp_db))*(close - (SELECT avg(close) FROM sp_db)) AS sp_cov_sq
FROM sp_db
WHERE date > 2000
SELECT *, sp_dev*stock_dev AS cross_dev
FROM sp_table
JOIN stock_table ON stock_table.stock_date = sp_date
WHERE sp_past_30 IS NOT NULL AND stock_daily_gain < 0.99 AND stock_daily_gain > -0.99;
CREATE TABLE beta_slope AS
SELECT sum((stock_daily_gain - (SELECT avg(stock_daily_gain) FROM stock_sp_table)) * (sp_daily_gain - (SELECT avg(sp_daily_gain) FROM stock_sp_table))) / sum((sp_daily_gain - (SELECT avg(sp_daily_gain) FROM stock_sp_table)) * (sp_daily_gain - (SELECT avg(sp_daily_gain) FROM stock_sp_table))) AS beta
FROM stock_sp_table;
SELECT *
SELECT *
FROM beta_slope;
'<Alternative Beta Calculation - Covariance Method>
Is it accurate? Not sure'
CREATE TABLE beta_cov_method AS
WITH sp_var_cov AS (
SELECT SUM(sp_cov_sq)/(COUNT(*) - 1) AS sp_var, sum(cross_dev)/(COUNT(*) - 1) AS sp_cov
SELECT sp_cov, sp_var, sp_cov / sp_var AS cov_method_beta
FROM sp_var_cov;
SELECT *
FROM beta_cov_method;
'<Finding CAGR>
Assumption 1: total number of years is 23.5 years
Asusmption 2: 10-year risk-free rate is 4.41%'
CREATE TABLE stat_table (ticker TEXT, rf_rate INTEGER, rm_rate INTEGER, beta_slope INTEGER, sp_var INTEGER, sp_cov INTEGER);
INSERT INTO stat_table (ticker, rf_rate, rm_rate, beta_slope, sp_var, sp_cov)
VALUES ('msft', 0.0441,
(SELECT POWER((SELECT close FROM sp_db ORDER BY date DESC LIMIT 1) / (SELECT close FROM sp_db ORDER BY date LIMIT 1), (1/23.5)) - 1),
(SELECT * FROM beta_slope),
(SELECT sp_var FROM beta_cov_method),
(SELECT sp_cov FROM beta_cov_method));
SELECT *, (rf_rate + (beta_slope) * (rm_rate - rf_rate)) AS CAGR
FROM stat_table;
'<Joining Financial Statements>'
CREATE TABLE fin_table AS
SELECT * FROM stock_is INNER JOIN stock_bs ON stock_is.period = stock_bs.period INNER JOIN stock_cf ON stock_bs.period = stock_cf.period;
'<Finding WACC and Growth Rate>
#step 1: create wacc table structure for wacc variables and growth rates
#step 2: insert values into each column
equity_c: CAGR
equity_w: Total Equity / Total Assets
debt_c: Interest Expense / Total Debt
debt_w: Total Liability / Total Assets
tax_r: corporate tax rate (21%)
growth_r: average between "CAGR" and "average of internal growth rate" (no reason for calc using this method, just to compensate for recent high growth)
term_g: 3%
Other line item growth rates: average of yoy growth rates from financial statements'
CREATE TABLE wacc_table (ticker TEXT, equity_c DECIMAL, equity_w DECIMAL, debt_c DECIMAL, debt_w DECIMAL, tax_r DECIMAL, growth_r DECIMAL, term_g DECIMAL, ebit_g DECIMAL, da_g DECIMAL, wc_g DECIMAL, capex_g DECIMAL);
INSERT INTO wacc_table (ticker, equity_c, equity_w, debt_c, debt_w, tax_r, growth_r, term_g, ebit_g, da_g, wc_g, capex_g)
VALUES ('msft',
(SELECT (rf_rate + (beta_slope) * (rm_rate - rf_rate)) FROM stat_table),
(SELECT [Stockholders Equity] / [Total Assets] FROM fin_table WHERE period = 'q2_24'),
(SELECT [Interest Expense]*1.0 / [Total Debt]*1.0 FROM fin_table WHERE period = 'q2_24'),
(SELECT ([Total Assets]-[Stockholders Equity]) / [Total Assets] FROM fin_table WHERE period = 'q2_24'), 0.21,
(((SELECT (rf_rate + (beta_slope) * (rm_rate - rf_rate)) FROM stat_table WHERE ticker = 'msft') + (SELECT avg(igr) FROM (SELECT period, ([Net Income] / [Total Assets] * [Retained Earnings] / [Net Income]) AS igr FROM fin_table))) / 2), 0.03,
(((((SELECT [EBIT] FROM fin_table WHERE period = 'q2_24') / (SELECT [EBIT] FROM fin_table WHERE period = 'q2_23')) - 1)+
(((SELECT [EBIT] FROM fin_table WHERE period = 'q2_23') / (SELECT [EBIT] FROM fin_table WHERE period = 'q2_22')) - 1)+
(((SELECT [EBIT] FROM fin_table WHERE period = 'q2_22') / (SELECT [EBIT] FROM fin_table WHERE period = 'q2_21')) -1)) / 3),
(((((SELECT [Depreciation And Amortization]*1.0 FROM fin_table WHERE period = 'q2_24') / (SELECT [Depreciation And Amortization]*1.0 FROM fin_table WHERE period = 'q2_23')) - 1)+
(((SELECT [Depreciation And Amortization]*1.0 FROM fin_table WHERE period = 'q2_23') / (SELECT [Depreciation And Amortization]*1.0 FROM fin_table WHERE period = 'q2_22')) - 1)+
(((SELECT [Depreciation And Amortization]*1.0 FROM fin_table WHERE period = 'q2_22') / (SELECT [Depreciation And Amortization]*1.0 FROM fin_table WHERE period = 'q2_21')) - 1)) / 3),
(((((SELECT [Working Capital]*1.0 FROM fin_table WHERE period = 'q2_24') / (SELECT [Working Capital]*1.0 FROM fin_table WHERE period = 'q2_23')) - 1)+
(((SELECT [Working Capital]*1.0 FROM fin_table WHERE period = 'q2_23') / (SELECT [Working Capital]*1.0 FROM fin_table WHERE period = 'q2_22')) - 1)+
(((SELECT [Working Capital]*1.0 FROM fin_table WHERE period = 'q2_22') / (SELECT [Working Capital]*1.0 FROM fin_table WHERE period = 'q2_21')) - 1)) / 3),
(((((SELECT [Capital Expenditure]*1.0 FROM fin_table WHERE period = 'q2_24') / (SELECT [Capital Expenditure]*1.0 FROM fin_table WHERE period = 'q2_23')) - 1)+
(((SELECT [Capital Expenditure]*1.0 FROM fin_table WHERE period = 'q2_23') / (SELECT [Capital Expenditure]*1.0 FROM fin_table WHERE period = 'q2_22')) - 1)+
(((SELECT [Capital Expenditure]*1.0 FROM fin_table WHERE period = 'q2_22') / (SELECT [Capital Expenditure]*1.0 FROM fin_table WHERE period = 'q2_21')) - 1)) / 3));
SELECT * FROM wacc_table;
SELECT ticker, ((equity_c * equity_w) + ((debt_w * debt_c) * (1 - tax_r))) AS WACC
FROM wacc_table;
'<Finding Implied Share Value>
#step 1: create a DCF table structure
#step 2: insert values into the DCF table
Number of years: 2 prior years + current year + 5 projected years + terminal value
Projected years and terminal values are calculated as present values
Assumption: ticker is "msft"'
CREATE TABLE dcf_table (ticker TEXT, period TEXT, cf INTEGER);
WITH wacc AS (SELECT (equity_c * equity_w) + ((debt_w * debt_c) * (1 - tax_r)) FROM wacc_table WHERE ticker = 'msft')
INSERT INTO dcf_table (ticker, period, cf)
VALUES
('msft', 'a1', (SELECT ([EBIT] * (1 - (SELECT tax_r FROM wacc_table)) + [Depreciation And Amortization] + [Change in Working Capital] + [Capital Expenditure]) FROM fin_table WHERE period = 'q2_22')),
('msft', 'a2', (SELECT ([EBIT] * (1 - (SELECT tax_r FROM wacc_table)) + [Depreciation And Amortization] + [Change in Working Capital] + [Capital Expenditure]) FROM fin_table WHERE period = 'q2_23')),
('msft', 'a3', (SELECT ([EBIT] * (1 - (SELECT tax_r FROM wacc_table)) + [Depreciation And Amortization] + [Change in Working Capital] + [Capital Expenditure]) FROM fin_table WHERE period = 'q2_24')),
('msft', 'pv_f1', ((SELECT ([EBIT] * (1 + (SELECT ebit_g FROM wacc_table)) * (1 - (SELECT tax_r FROM wacc_table)) + [Depreciation And Amortization] * (1 + (SELECT da_g FROM wacc_table)) + [Change in Working Capital] * (1 + (SELECT wc_g FROM wacc_table)) + [Capital Expenditure] * (1 + (SELECT capex_g FROM wacc_table))) FROM fin_table WHERE period = 'q2_24')) / (1 + (SELECT * FROM wacc))),
('msft', 'pv_f2', ((SELECT ([EBIT] * POWER((1 + (SELECT ebit_g FROM wacc_table)), 2) * (1 - (SELECT tax_r FROM wacc_table)) + [Depreciation And Amortization] * POWER((1 + (SELECT da_g FROM wacc_table)), 2) + [Change in Working Capital] * POWER((1 + (SELECT wc_g FROM wacc_table)), 2) + [Capital Expenditure] * POWER((1 + (SELECT capex_g FROM wacc_table)), 2)) FROM fin_table WHERE period = 'q2_24')) / POWER((1 + (SELECT * FROM wacc)), 2)),
('msft', 'pv_f3', ((SELECT ([EBIT] * POWER((1 + (SELECT ebit_g FROM wacc_table)), 3) * (1 - (SELECT tax_r FROM wacc_table)) + [Depreciation And Amortization] * POWER((1 + (SELECT da_g FROM wacc_table)), 3) + [Change in Working Capital] * POWER((1 + (SELECT wc_g FROM wacc_table)), 3) + [Capital Expenditure] * POWER((1 + (SELECT capex_g FROM wacc_table)), 3)) FROM fin_table WHERE period = 'q2_24')) / POWER((1 + (SELECT * FROM wacc)), 3)),
('msft', 'pv_f4', ((SELECT ([EBIT] * POWER((1 + (SELECT ebit_g FROM wacc_table)), 4) * (1 - (SELECT tax_r FROM wacc_table)) + [Depreciation And Amortization] * POWER((1 + (SELECT da_g FROM wacc_table)), 4) + [Change in Working Capital] * POWER((1 + (SELECT wc_g FROM wacc_table)), 4) + [Capital Expenditure] * POWER((1 + (SELECT capex_g FROM wacc_table)), 4)) FROM fin_table WHERE period = 'q2_24')) / POWER((1 + (SELECT * FROM wacc)), 4)),
('msft', 'pv_f5', ((SELECT ([EBIT] * POWER((1 + (SELECT ebit_g FROM wacc_table)), 5) * (1 - (SELECT tax_r FROM wacc_table)) + [Depreciation And Amortization] * POWER((1 + (SELECT da_g FROM wacc_table)), 5) + [Change in Working Capital] * POWER((1 + (SELECT wc_g FROM wacc_table)), 5) + [Capital Expenditure] * POWER((1 + (SELECT capex_g FROM wacc_table)), 5)) FROM fin_table WHERE period = 'q2_24')) / POWER((1 + (SELECT * FROM wacc)), 5)),
('msft', 'pv_tv', (((SELECT ([EBIT] * (1 - (SELECT tax_r FROM wacc_table)) + [Depreciation And Amortization] + [Change in Working Capital] + [Capital Expenditure]) FROM fin_table WHERE period = 'q2_24') * (1 + (SELECT term_g FROM wacc_table)))/((SELECT (equity_c * equity_w) + ((debt_w * debt_c) * (1 - tax_r)) FROM wacc_table) - (SELECT term_g FROM wacc_table))) / (1 + (SELECT * FROM wacc)));
SELECT * FROM dcf_table;
SELECT ROUND((sum(cf) + (SELECT [Cash And Cash Equivalents] FROM fin_table WHERE period = 'q2_24') - (SELECT [Total Debt] FROM fin_table WHERE period = 'q2_24')) / (SELECT [Ordinary Shares Number] FROM fin_table), 2) AS 'Implied Share Price'
FROM dcf_table
WHERE ticker = 'msft';
Any help / suggestions would be greatly appreciated
Thank you!
SJ Park
