Skip to Main Content
Connecting to a remote DB from inside a shell script
1826067Mar 20 2014 — edited May 31 2014
Hi All,
This is my first post here, so not sure if this is the correct community for this post.
I want to be able to connect remotely to a database from a shell script and run some queries, however I'm unable to do so.
Here is the code snippet being used:
execute_dg ()
paswd=$2
prmy=$1
user="sys/$paswd"
sqlplus -s <<EOF |tee -a $LOGFILE
set echo on
set pages 0
set heading off
set lines 200
  $3
EOF
return $?
check_pre_fb ()
paswd=$2
prmy=$1
lag=`execute_dg $prmy $paswd $query`
info "Current Archive log gap between Primary & Standby is :$lag"
echo "Please"
enable_fb_sby ()
echo "Enter Primary DB name" | tee -a $LOGFILE
read prmy
echo "Enter Sys password"  | tee -a $LOGFILE
read -s pswd
check_pre_fb $prmy $pswd
The error while debugging is a s below:
++ user='sys/*******'
++ sqlplus -s '"sys/********"@prmy11' as sysdba
++ tee -a /sys_apps_01/ogg/testpre.log
++ return 0
+ lag='
SP2-0306: Invalid option.
Usage: CONN[ECT] [{logon|/|proxy} [AS {SYSDBA|SYSOPER|SYSASM}] [edition=value]]
where <logon> ::= <username>[/<password>][@<connect_identifier>]
      <proxy> ::= <proxyuser>[<username>][/<password>][@<connect_identifier>]'
+ info 'Current Archive log gap between Primary & Standby is :
Any ideas?
Comments
Locked Post
New comments cannot be posted to this locked post.
Post Details
Locked due to inactivity on Jun 28 2014
Added on Mar 20 2014
4 comments
