Skip to Main Content
Oracle Forms
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
SYSTEM VARIABLE - SYSTEM.CURSOR_RECORD, SYSTEM.CURRENT_BLOCK.
VijethaNov 20 2013 — edited Nov 27 2013
Hi All;
I am unable to understand coding of the form which is already created by someone else long time ago, now have to make some changes in it.
There are many data-blocks in this form, like ENQACMHDR, ENQACMDTL, ENQACEHDR, BUTTON, DRGCHK, etc.
and there are many push button created for ENTER_QUERY, EXECUTE_QUERY, NEXT, PREVIOUS, FIRST, LAST, SAVE, CLEAR, EXIT, AMEND, etc.
When i run the form , i can enter all the data & save, the cursor allows me to enter in the 'ENQACMDTL' block,
But the problem is when i click on 'ENTER_QUERY' BUTTON, i must be able to query in the 'ENQACMDTL' block, but i am unable to even click on the field items of 'ENQACMDTL' block.
It is being blocked somewhere & i am not able to find out. Mainly i am not able to understand the following what exactly is this POST-BLOCK Trigger doing, I don't know what SYSTEM.CURRENT_BLOCK & SYSTEM.CURSOR_RECORD is doing?
FORM:TRIGGER : POST-BLOCK:
:GLOBAL.BLOCK := :SYSTEM.CURRENT_BLOCK;
The below trigger is for 'ENQACMDTL' data-block.
WHEN-NEW-RECORD-INSTANCE:
:ENQACMDTL.ITEM := :SYSTEM.CURSOR_RECORD;
The below trigger is for 'ENTER_QUERY' PUSH BUTTON.
PUSH BUTTON: ENTER_QUERY: WHEN BUTTON PRESSED :
DECLARE
  IT_ID1 ITEM;
  IT_ID2 ITEM;
  IT_ID3 ITEM;
  IT_ID4 ITEM;
  IT_ID5 ITEM;
  IT_ID6 ITEM;
  IT_ID7 ITEM;
  SENDTOE ITEM;
  SENDTOM ITEM;
BEGIN
  IT_ID1 := FIND_ITEM('BUTTON.EN_QUERY');
  IT_ID2 := FIND_ITEM('BUTTON.CA_QUERY');
  IT_ID3 := FIND_ITEM('BUTTON.EX_QUERY');
  IT_ID4 := FIND_ITEM('BUTTON.CLEAR');
  IT_ID5 := FIND_ITEM('BUTTON.SAVE');
  IT_ID6 := FIND_ITEM('BUTTON.PENDING');
  IT_ID7 := FIND_ITEM('BUTTON.AMEND');
  SENDTOE := FIND_ITEM('ENQACMHDR.SENDTOENGG');
  SENDTOM := FIND_ITEM('ENQACEHDR.SENDTOMKTG');
  SET_ITEM_PROPERTY(IT_ID3,ENABLED,PROPERTY_TRUE);
  if :system.mode<>'ENTER-QUERY' THEN
   set_item_property (it_id1,label,'CANCEL QUERY');
     SET_ITEM_PROPERTY(IT_ID4,ENABLED,PROPERTY_FALSE);
     SET_ITEM_PROPERTY(IT_ID5,ENABLED,PROPERTY_FALSE);
     SET_ITEM_PROPERTY(IT_ID6,ENABLED,PROPERTY_TRUE);
   SET_ITEM_PROPERTY(IT_ID7,ENABLED,PROPERTY_FALSE);
   --  GO_BLOCK('ENQACMHDR');
  --  if :PARAMETER.ENQPAR ='MKTG' then
-- end if;
   --CLEAR_BLOCK(NO_VALIDATE);
   ENTER_QUERY;
  set_item_property (it_id1,label,'ENTER QUERY');
  SET_ITEM_PROPERTY(IT_ID3,ENABLED,PROPERTY_FALSE);
  SET_ITEM_PROPERTY(IT_ID4,ENABLED,PROPERTY_TRUE);
  SET_ITEM_PROPERTY(IT_ID5,ENABLED,PROPERTY_TRUE);
     SET_ITEM_PROPERTY(IT_ID6,ENABLED,PROPERTY_FALSE);
     SET_ITEM_PROPERTY(IT_ID7,ENABLED,PROPERTY_TRUE);
      IF :PARAMETER.ENQPAR ='ENGG' THEN
  GO_ITEM('ENQACMHDR.ENQNO');
  END IF;
  IF :ENQACMHDR.LOCKM = 1 THEN
   SET_ITEM_PROPERTY(SENDTOE,ENABLED,PROPERTY_FALSE);
  ELSE
   SET_ITEM_PROPERTY(SENDTOE,ENABLED,PROPERTY_TRUE);
  END IF;
  IF :ENQACEHDR.LOCKE = 1 THEN
   SET_ITEM_PROPERTY(SENDTOM,ENABLED,PROPERTY_FALSE);
  ELSE
   SET_ITEM_PROPERTY(SENDTOM,ENABLED,PROPERTY_TRUE);
  END IF;
  ELSE
  EXIT_FORM;
  END IF;
-- set_item_property('button.save',enabled,property_true);
END;
What must be changed in order to unblock the ENQACMDTL' block and allow it to be queried??
Help me please, Thank You.
Oracle9i Enterprise Edition Release 9.2.0.1.0 - Production
Oracle Forms 6i.
Comments
Locked Post
New comments cannot be posted to this locked post.
Post Details
Locked on Dec 25 2013
Added on Nov 20 2013
18 comments
