Skip to Main Content
Infrastructure Software
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
Shell script Block not being executed after FOR loop for checking Database status
user12195658Nov 16 2017 — edited Nov 18 2017
Hi there,
i have created a shell script on a central Machine which checks for the status of databases running remotely on different servers.
i test it by a shell script which connects the remote database instance through tns entry and then executing the sql query.
if the instance is down or for some reason not accessible, query execution fails with Error (any error string will contain "ERROR", which i will grep and send mail).
since there are sometime higher resource consumption, even if database is not down, some time it gives some false alarm that DB is down.Hence to avoid these false alarm, after grepping the ERROR for the first time,i am making the shell script to wait for 15-20 seconds then connect to sqlplus and again grep the ERROR to make sure that DB is really down.
below is my script:
DBALIST="dbasupport@xyzcom;export DBALIST
export PATH=/usr/bin:/usr/sbin
        if [ -f /usr/bin/less ]; then
        export PAGER="/usr/bin/less -ins"
        elif [ -f /usr/bin/more ]; then
        export PAGER="/usr/bin/more -s"
        fi
        case ${SHELL} in
        *bash)
        typeset +x PS1="\u@\h:\w\\$ "
        esac
        export ORACLE_HOME=/oracle11/oracle12/app/oracle12/product/12.2.0/dbhome_1
        export ORACLE_BASE=/oracle11/oracle12/app/oracle12
        export TNS_ADMIN=/oracle11/oracle12/app/oracle12/product/12.2.0/dbhome_1/network/admin
        PATH=$PATH:$ORACLE_HOME/bin
        LD_LIBRARY_PATH=$ORACLE_HOME/lib:/usr/lib
        export LD_LIBRARY_PATH
        cat /dev/null/ > /tmp/alert1.txt
sqlplus -s system/*****@db1 << EOF >> /tmp/alert1.txt
select name from v\$database;
exit
EOF
First check==>if cat /tmp/alert1.txt | grep 'ERROR' >/dev/null 2>&1;  then
                       (cat /dev/null/ > /tmp/alert1.txt
                     for i in {1..1}
                do
                sleep 5
                echo "Hello" ====> to check this step is executed after 10 sec.
                done
                fi
                echo "Hello World" ====> to check this step is executed after above block
Second Check==>sqlplus -s system/****@db1 << EOF >> /tmp/alert1.txt #execute successfully#
                exit
                EOF
##IT DOES NOT EXECUTE BELOW BLOCK##
             echo "To:dbasupport@abc.com"
             echo "MIME-Version: 1.0"
             echo "Subject: Alert : Database Instance db1 is DOWN.Please Check Immediatly `date` "
             echo "Content-Type: text/html"
             echo "<body bgcolor="ACFFA2">"
             echo "<font size=5 color=Red><b> Database Instance db1 is DOWN. `date` </b></font>"
             )| sendmail -t
            fi
bash-4.2$ cat /tmp/alert1.txt
ERROR:  <=====================GREP THIS STRING
ORA-12514: TNS:listener does not currently know of service requested in connect
descriptor
SP2-0306: Invalid option.
Usage: CONN[ECT] [{logon|/|proxy} [AS {SYSDBA|SYSOPER|SYSASM|SYSBACKUP|SYSDG|SYSKM|SYSRAC}] [edition=value]]
where <logon> ::= <username>[/<password>][@<connect_identifier>]
      <proxy> ::= <proxyuser>[<username>][/<password>][@<connect_identifier>]
ERROR:
ORA-12162: TNS:net service name is incorrectly specified
SP2-0157: unable to CONNECT to ORACLE after 3 attempts, exiting SQL*Plus
where i am doing wrong..spent a lot of time and effort but no luck..help is highly appreciated..
thaks
Comments
Locked Post
New comments cannot be posted to this locked post.
Post Details
Locked on Dec 16 2017
Added on Nov 16 2017
10 comments
