rep-0118 problem. Not able to fix it need help.
csphardMar 11 2009 — edited Mar 13 2009Problem. I installed Oracle Report Builder 10.1.2.0.2
I get the following error message when I try to open it.
REP-0118: Unable to create a temporary file.
I have done the following:
added to the win.ini file
[Oracle]
ora_config=g:\orawin\oracle.ini
I search the registry to do the following:
You have to change registry settings by going through REGEDIT. Under hkey_local_machine/software/oracle/<oracle home>,
look for variable REPORTS_TMP. Change value for this, for example c:\tmpfiles or something
like that where you want oracle reports to create temp files.
But could not find the REPORTS_TMP.
What am I missing here.
Howard
