Skip to Main Content
SQL & PL/SQL
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
Problems ignoring an index using the NO_INDEX hint
268133Jan 23 2003 — edited Jun 6 2013
I have a query that appears perform better when not using a specific index (my_index). However other queries do appear to benefit from this index.
If I do an explain on the query it shows “INDEX FAST FULL SCAN my_index”
This query uses my_table in the outer query as well as an inner query.
In an attempt to stop my_index being used I have tried the NO_INDEX hint and functions. For example, the following syntax when tried on both queries did not work.
Select /*+NO_INDEX(my_table)*/ my_table.my_column from … .
Select /*+NO_INDEX(my_table my_index)*/ my_table.my_column from …
Is their a problem with the NO_INDEX hint ?
Are their conditions where the NO_INDEX hint is ignored ?
The indexed columns are CHAR(10) and CHAR(10) and trying to invalidate the Index by using a function also did not work, such as
…. where TRIM(my_table.my_column_a) in (‘EXECUTED’,’NOTEXECD’)
and TRIM(my_table.my_column_b) in (‘VERIFIED’,’NOTVERIF’) …
and ….
But this also does not work.
Any other suggestions as to how I might be able to turn if the use of my_index for this query?
I would post the actual SQL but I am at a customer site and they are very concerned about anything being sent out of their network.
Comments
Locked Post
New comments cannot be posted to this locked post.
Post Details
Locked on Jul 4 2013
Added on Jan 23 2003
10 comments
