Skip to Main Content
SQLcl: MCP Server & SQL Prompt
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
Problem with SQLcl Project's "project stage" command
Nikola ŠupićApr 7 2026 — edited Apr 7 2026
I do not know if this is right thread.
I used project export command, it executed fine, git commited my work, tried to do project stage and got java heap space error :/
Before everything, I updated my version of SQLcl to 26.1.0.0
Tried both from VSCode and cmd
SQL> project stage
The current connection ADMIN will be used for all operations
Exception in thread "main" java.lang.OutOfMemoryError: Java heap space
       at oracle.dbtools.parser.Parser$EarleyCell.mergeWithAlloc(Parser.java:565)
       at oracle.dbtools.parser.Parser$EarleyCell.merge(Parser.java:533)
       at oracle.dbtools.parser.Earley.merge(Earley.java:444)
       at oracle.dbtools.parser.Earley.predict(Earley.java:424)
       at oracle.dbtools.parser.Earley.doParse(Earley.java:111)
       at oracle.dbtools.parser.Parsed.getRoot(Parsed.java:127)
       at oracle.dbtools.arbori.Program.eval(Program.java:1389)
       at oracle.dbtools.arbori.SqlProgram.run(SqlProgram.java:77)
       at oracle.dbtools.arbori.SqlProgram.run(SqlProgram.java:63)
       at oracle.dbtools.arbori.SqlProgram.run(SqlProgram.java:58)
       at oracle.dbtools.arbori.SqlProgram.run(SqlProgram.java:89)
       at oracle.dbtools.app.SqlRecognizer.recognize(SqlRecognizer.java:82)
       at oracle.dbtools.app.SqlRecognizer.<init>(SqlRecognizer.java:47)
       at oracle.dbtools.extension.project.commands.stage.objectclasses.DbDiffObject.<init>(DbDiffObject.java:162)
       at oracle.dbtools.extension.project.core.utils.GitUtils.diffBranches(GitUtils.java:311)
       at oracle.dbtools.extension.project.commands.stage.StageCommand.run(StageCommand.java:100)
       at oracle.dbtools.extension.project.commands.handler.CommandHandler.StageCommand(CommandHandler.java:59)
       at oracle.dbtools.extension.project.commands.handler.ProjectCommand.handleEvent(ProjectCommand.java:88)
       at oracle.dbtools.raptor.newscriptrunner.util.command.ParsedCommandListener.handleEvent(ParsedCommandListener.java:66)
       at oracle.dbtools.raptor.newscriptrunner.CommandRegistry.lambda$fireListeners$4(CommandRegistry.java:485)
       at oracle.dbtools.raptor.newscriptrunner.CommandRegistry$$Lambda$392/0x0000000800e40690.run(Unknown Source)
       at oracle.dbtools.raptor.newscriptrunner.ScriptRunnerContext.runWithStoredContext(ScriptRunnerContext.java:839)
       at oracle.dbtools.raptor.newscriptrunner.CommandRegistry.runWithStoredContext(CommandRegistry.java:705)
       at oracle.dbtools.raptor.newscriptrunner.CommandRegistry.fireListeners(CommandRegistry.java:463)
       at oracle.dbtools.raptor.newscriptrunner.ScriptRunner.lambda$run$0(ScriptRunner.java:241)
       at oracle.dbtools.raptor.newscriptrunner.ScriptRunner$$Lambda$376/0x0000000800e3cbd0.run(Unknown Source)
       at oracle.dbtools.raptor.newscriptrunner.ScriptRunner.run(ScriptRunner.java:124)
       at oracle.dbtools.raptor.newscriptrunner.ScriptExecutor.run(ScriptExecutor.java:364)
       at oracle.dbtools.raptor.newscriptrunner.ScriptExecutor.run(ScriptExecutor.java:245)
       at oracle.dbtools.raptor.scriptrunner.cmdline.SqlCli.processLine(SqlCli.java:1512)
       at oracle.dbtools.raptor.scriptrunner.cmdline.SqlCli.runSqlcl(SqlCli.java:1756)
Comments
Post Details
Added on Apr 7 2026
2 comments
