Skip to Main Content
Java Development Tools
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
Problem in finding Cursor Position using Java Script for an Input TextField
857502Feb 6 2012 — edited Feb 13 2012
Hi,
I have a problem with finding the cursor position from a inputText field component.
Used the following java script code to achieve it. The same functionality is working fine if i run in a simple html page. But when used the same javascript inside jsff it is not returning the cursor position.
var adfComponent = AdfPage.PAGE.findComponentByAbsoluteId("r1:1:it3");
var adfComponentClientId = adfComponent.getClientId();
var div = document.getElementById(adfComponentClientId + '::content');
div.focus();
var docSelectionRange = document.selection.createRange();
docSelectionRange.moveStart ('character', -div.value.length);
var iCaretPos = docSelectionRange.text.length;
alert("iCaretPos --> "+iCaretPos);  ---> This statement always returning '0'. Instead, i want the cursor position inside the text box.
Please let me know what am i missing.
For your reference, sending the sample html page which is working fine with the same kind of code.
<html>
 <body style="font-family: tahoma; font-size: 8pt;">
  <script language="JavaScript">
   **  Returns the caret (cursor) position of the specified text field.
   **  Return value range is 0-oField.length.
   function doGetCaretPosition (oField) {
     var iCaretPos = 0;
		alert(oField);
     if (document.selection) {
       // Set focus on the element
       oField.focus ();
       // To get cursor position, get empty selection range
       var oSel = document.selection.createRange ();
       // Move selection start to 0 position
       oSel.moveStart ('character', -oField.value.length);
       // The caret position is selection length
       iCaretPos = oSel.text.length;
     // Firefox support
     else if (oField.selectionStart || oField.selectionStart == '0')
       iCaretPos = oField.selectionStart;
     // Return results
     return (iCaretPos);
  </script>
  <form name="blah">
   Text Field: <input type="text" name="nameEdit" value="">
   <input type="button" value="Get Caret" onClick="document.getElementById('where').value=doGetCaretPosition (document.forms[0].elements[0]);">
<input id="where">
  </form>
 </body>
</html>
Thanks & Regards,
Kiran Konjeti
Edited by: Kiran Konjeti on Feb 6, 2012 12:00 PM
This post has been answered by Frank Nimphius-Oracle on Feb 9 2012
Jump to Answer
Comments
Locked Post
New comments cannot be posted to this locked post.
Post Details
Locked on Mar 12 2012
Added on Feb 6 2012
5 comments
