Skip to Main Content
Oracle Database Express Edition (XE)
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
Problem connecting using VB Oracle Data Control oradc.ocx but otherwise ok.
847365Mar 15 2011 — edited Mar 15 2011
I am trying to run one of the sample vb apps DataCtrl that uses the Oracle Data Control (oradc.ocx) to simplify connecting to a database and getting the data into a databound control. I have tried every combination of name/id/pw and get the same error - ORA-12154:TNS:could not resolve service name.
I have 2 of the sample databases created - "employees" and "demo". Using XE, i can open and view both db's with no problem. Using the ODBC configuration dialog I can configure and test the connection to both and tests ok. I have used programs to convert Oracle to Excel and Excel to Oracle and both find the db with no problem either.
If I tnsping to XE, employees or demo, the response is negative. The file tnsnames.ora exists in the /admin dir and lists only XE. The file sqlnet.ora has nothing (except comments) in it.
I have read every bit of documentation on the internet and no help. I just opened "employees" and "demo" again with XE without a problem. However when I try to run the Oracle/Excel conversion programs now, they are now showing the 'name error also. I have tried both the sample VB app and the Oracle/Excel converter programs with XE/employees open and closed and it makes no difference.
Everything that I have read indicates that you should be able to use the actual db name, ie; "employees". I have run out of combinations of names/ids/pws and hope I can get some help here. Thanks in advance.
Comments
Locked Post
New comments cannot be posted to this locked post.
Post Details
Locked on Apr 12 2011
Added on Mar 15 2011
1 comment
