Skip to Main Content
SQL Developer Data Modeler
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
Missing script engine JRuby Engine
puchtecMar 10 2011 — edited Apr 27 2011
I get the error There is one or more missing script engines on the system. Please check the libraries colored in red. when opening Custom Libraries (Tools .. Design Rules .. Libraries). The JRuby Engine is colored red.
What's next?
* How (where) do I get the JRuby Engine? (What is to be loaded from http://www.jruby.org)
* Where do I have to install the JRuby Engine? Is it just a extract from a downloaded zip file, should it be provided in a separate directory?
Thanks in advance,
puchtec
3.0.0.665 on Windows XP
Comments
Locked Post
New comments cannot be posted to this locked post.
Post Details
Locked on May 25 2011
Added on Mar 10 2011
9 comments
