Skip to Main Content
Oracle Forms
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
load: class oracle.forms.engine.Main not found Stuck at loading Java Applet
Scott HillierSep 9 2008 — edited Sep 9 2008
Hi there
I have recently installed App Server 10.1.2.0 on a new machine.
Copied all my forms to an appropriate directory. Set up formsweb.cfg to allow them to run and have attempted to run them.
Unfortunately I get stuck at the Loading Java Applet screen, and in the status bar at the bottom it says :
I have taken a look at the Java Console, and the 2 things that jump out at me are that it appears to be looking for a forms90 directory, which seems odd since I am using App Server 10.1.2.0.2 and Forms Builder 10.1.2.0.2 meaning it should be looking in a forms directory not forms90 directory shouldnt it ?
And also, it mentions class with no proxy, so on looking around the forums it has been suggested that put the proxy details into jinitiator, which I have done, but this has made no difference either.
Can anyone suggest anything else please ?
Java Console log follows.
Thanks a lot
Scott
Oracle JInitiator: Version 1.3.1.9
Using JRE version 1.3.1.9 Java HotSpot(TM) Client VM
User home directory = C:\Documents and Settings\hilliers
c: clear console window
f: finalize objects on finalization queue
g: garbage collect
h: display this help message
l: dump classloader list
m: print memory usage
q: hide console
s: dump system properties
t: dump thread list
x: clear classloader cache
0-5: set trace level to <n>
Unregistered modality listener
Removed trace listener: sun.plugin.ocx.ActiveXAppletViewer[oracle.forms.engine.Main,0,0,914x613,layout=java.awt.BorderLayout]
Sending events to applet. STOP
Sending events to applet. DESTROY
Sending events to applet. DISPOSE
Sending events to applet. QUIT
Finding information...
Releasing classloader: sun.plugin.ClassLoaderInfo@d9850, refcount=0
Caching classloader: sun.plugin.ClassLoaderInfo@d9850
Current classloader cache size: 1
Done...
Registered modality listener
Referencing classloader: sun.plugin.ClassLoaderInfo@d9850, refcount=1
Added trace listener: sun.plugin.ocx.ActiveXAppletViewer[oracle.forms.engine.Main,0,0,914x613,invalid,layout=java.awt.BorderLayout]
Sending events to applet. LOAD
Sending events to applet. INIT
Sending events to applet. START
Determine if the applet requests to install any HTML page
HTML Installation finished.
Opening http://appserver008/forms90/java/oracle/forms/engine/Main.class
Connecting http://appserver008/forms90/java/oracle/forms/engine/Main.class with no proxy
load: class oracle.forms.engine.Main not found.
java.lang.ClassNotFoundException: java.io.IOException: open HTTP connection failed.
at sun.applet.AppletClassLoader.getBytes(Unknown Source)
at sun.applet.AppletClassLoader.access$100(Unknown Source)
at sun.applet.AppletClassLoader$1.run(Unknown Source)
at java.security.AccessController.doPrivileged(Native Method)
at sun.applet.AppletClassLoader.findClass(Unknown Source)
at sun.plugin.security.PluginClassLoader.findClass(Unknown Source)
at java.lang.ClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadClass(Unknown Source)
at sun.applet.AppletClassLoader.loadCode(Unknown Source)
at sun.applet.AppletPanel.createApplet(Unknown Source)
at sun.plugin.AppletViewer.createApplet(Unknown Source)
at sun.applet.AppletPanel.runLoader(Unknown Source)
at sun.applet.AppletPanel.run(Unknown Source)
at java.lang.Thread.run(Unknown Source)
This post has been answered by François Degrelle on Sep 9 2008
Jump to Answer
Comments
Locked Post
New comments cannot be posted to this locked post.
Post Details
Locked on Oct 7 2008
Added on Sep 9 2008
2 comments
