JRE System-level settings does not work - JRE1.6.30
ilputtoFeb 20 2012 — edited Feb 21 2012Good day,
I need to set deployment.security.mixcode parameter to "DISABLE" within of deployment.properties configuration file.
Also I wish to place the deployment.properties configuration file is not user-specific path. The default location is
<User Application Data Folder>\Sun\Java\Deployment\deployment.properties.
TO change the default location I read about possibility to use the deployment.config for specifying the System-Level
deployment.properties in the infrastructure.
Unfortunatelly seems does not work. Someone have got experience about system level settings of deployment.properties?
This is the configuration I have used.
deployment.config:
deployment.system.config.mandatory=FALSE
deployment.system.config=file/:C:\Program Files\Java\jre6\lib\deployment.properties
deployment.properties:
#deployment.properties
#Fri Feb 17 15:54:57 CET 2012
deployment.version=6.0
deployment.capture.mime.types=true
deployment.browser.path=C\:\\Program Files\\Internet Explorer\\iexplore.exe
#Java Deployment jre's
deployment.javaws.jre.0.product=1.6.0_31
deployment.javaws.jre.0.registered=true
deployment.javaws.jre.0.osname=Windows
deployment.javaws.jre.0.platform=1.6
deployment.javaws.jre.0.path=C\:\\Program Files\\Java\\jre6\\bin\\javaw.exe
deployment.javaws.jre.0.location=http\://java.sun.com/products/autodl/j2se
deployment.javaws.jre.0.enabled=true
deployment.javaws.jre.0.osarch=x86
deployment.security.mixcode=DISABLE <<====
Thank you in advance
Adriano C.
Edited by: user12025469 on Feb 20, 2012 6:23 AM
Edited by: user12025469 on Feb 20, 2012 7:48 AM
