Skip to Main Content
Database Software
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
Help,Problem while sync. data on iPAQ,Help
133008Dec 20 2002
Hi all,
I am using consolidator API to create Publications Items for few tables from my oracle8i schema.When i try to sync the user on my handheld for the first time it works fine.But if i try to recreate the publication removing a publication items that was earlier created and then try to sync again it gives me an error.
But if i remove 'conscli.odb' and 'xxxx.odb'(database) created earlier and then try to sync again the synchronization completes successfully.
I feel there is something wrong because its not logical to delete database files before synhronization after every publishing.
If somebody can correct me or some better suggestions please...........help me
Comments
Locked Post
New comments cannot be posted to this locked post.
Post Details
Locked on Jan 17 2003
Added on Dec 20 2002
0 comments
