Skip to Main Content
SQL & PL/SQL
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
Getting parts of a string (using regexp_instr, REVERSE, ...)
915879Mar 27 2012 — edited Mar 29 2012
Hi,
I'm trying to alter our company's existing procedure, so that it can extract the Nr of the house, and the bus ('mailbox') from the field "pio_address.street_nr_bus".
Now, if the input is something simple like "Testlane 15 A", there's no problem ofcourse, but since the data comes from what people entered in a form (on our site for example), it can get really messy and the input might be like:
[streetpart1] [streetpart2] [streetpart 3] [NR] [NRpart2] [mailbox] ==> ex: "Test 2 Lane 15 B A"
So in that example, I'd like to get "15 B A" (being a combination of house-nr and mailbox-nr)
So what I've come op with for now (would love to simplify it though) is the following code; but the procedure takes 30 minutes to complete now (~7000 records), which seems rather long, especially since it used to last like 5-10 minutes.
Any ideas/tips?
code:
SELECT REGEXP_REPLACE(trim(REVERSE(pio_address.street_nr_bus)),' *',' ') INTO pio_address.street_nr_bus
FROM DUAL;
SELECT REGEXP_INSTR(pio_address.street_nr_bus, '[[:digit:]INTO v_posnr FROM DUAL;
SELECT REGEXP_INSTR(pio_address.street_nr_bus, '[[:alpha:]]', v_posnr) INTO v_posstreet FROM DUAL;
IF v_posstreet = 0 THEN
SELECT REVERSE(pio_address.street_nr_bus) INTO v_nrbus FROM DUAL;
ELSE
SELECT trim(REVERSE(substr(pio_address.street_nr_bus,1, v_posstraat-1))) INTO v_nrbus FROM DUAL;
END IF;
*****UPDATE*****
it appears that this part of the code isn't what's slowing the procedure down, but if someone still knows a "shorter" way to accomplish what I'm doing with this code, tips are always welcome
Edited by: user11236545 on Mar 27, 2012 2:47 AM
Edited by: user11236545 on Mar 27, 2012 2:49 AM
Comments
Locked Post
New comments cannot be posted to this locked post.
Post Details
Locked on Apr 26 2012
Added on Mar 27 2012
4 comments
