Connection issues between 64 bit SSIS and Oracle in 64bit
445547Sep 14 2007 — edited Sep 23 2009I've got a Win2K3 Std Ed server (x64) running 64-bit SQL Server 2005 Enterprise Edition. I've installed the Oracle 10g 64 bit and and installed ODAC 64 bit then oracle patch to take care of () issue, i managed to create a link server on management studio and connect to oracle a 64 bit server
Now... when I try to create a new connection manager in SQL Server 2005 Integration Services i got the following error, the OLEDB provider for Oracle can't be found, and when I try to manually add an underlying OLEDB connection to the database, SQL Server reports: i got the following error....
Test connection failed because of an error in initializing provider. The 'OraOLEDB.Oracle.1' provider is not registered on the local machine.
Note: my sql server agent is not running on this server, let me know if this is an issue.
