Skip to Main Content
SQL & PL/SQL
Announcement
For appeals, questions and feedback about Oracle Forums, please email oracle-forums-moderators_us@oracle.com. Technical questions should be asked in the appropriate category. Thank you!
ORA-22835: Buffer too small for CLOB to CHAR or BLOB to RAW conversion (actual: 764123, maximum: 400
3134376Feb 8 2018 — edited Feb 9 2018
Hi All,
I am try to convert / read data of a clob column but getting ORA-22835.
Kindly requesting you to advise how I can read a CLOB data as rows in oracle database 12.1.
WITH t (order_number, line#, line, debug_message) as (
SELECT order_number, 1, regexp_substr (TO_CHAR (debug_message), '^.*?$', 1, 1, 'm'), substr (TO_CHAR (debug_message), regexp_instr (debug_message, '$', 1, 1, 1, 'm') + 1)
FROM order_logs
WHERE order_number = 789587
  UNION ALL
SELECT order_number, line#+1, regexp_substr(debug_message, '^.*?$', 1, 1, 'm'),  substr(debug_message, regexp_instr(debug_message, '$', 1, 1, 1, 'm')+1)
  FROM t
  WHERE debug_message IS NOT NULL) CYCLE order_number, line# SET IS_CYCLE to '1' default '0'
  SELECT line#, line
   FROM t
  ORDER BY order_number, line#;
ORA-22835: Buffer too small for CLOB to CHAR or BLOB to RAW conversion (actual: 764123, maximum: 4000)
22835. 00000 -  "Buffer too small for CLOB to CHAR or BLOB to RAW conversion (actual: %s, maximum: %s)"
*Cause:    An attempt was made to convert CLOB to CHAR or BLOB to RAW, where
           the LOB size was bigger than the buffer limit for CHAR and RAW
           types.
           Note that widths are reported in characters if character length
           semantics are in effect for the column, otherwise widths are
           reported in bytes.
*Action:   Do one of the following
           1. Make the LOB smaller before performing the conversion,
           for example, by using SUBSTR on CLOB
           2. Use DBMS_LOB.SUBSTR to convert CLOB to CHAR or BLOB to RAW.
Comments
Locked Post
New comments cannot be posted to this locked post.
Post Details
Locked on Mar 9 2018
Added on Feb 8 2018
19 comments
